Overclockability
15 Feb 2008
Howdy,
How well will a Q6600 OC with my Gigabyte P35-DS3 board, 2GB 6400 OCZ RAM, and the AC Pro 7.
Anyone have this combination?
Ta!
EDIT: how good is the Q6600 OC to 3GHz or even 3.3GHz that is being advertised?
I just clocked my Q6600 to 3ghz on stock voltage last night. I have the same board but a different cooler. Idle temps are between 27 and 30 degrees across cores.
I would imagine that to clock to 3.3ghz you would need to raise the vcore to 1.4v. I only ever wanted to clock to 3ghz so wont really try to go any higher.
