For 1920x1200? 8800GT 512MB will be fitted with a Accelero S1 + 12cm fan, so I presume overclock by quite a bit. Fan is a 800rpm ish fan
8800GTS will be with stock double width cooler, overclocked.
So which'll be faster? Case cooling won't be a problem, Stacker 810 with two 12cm exhaust fans. Currently running X1900XTX overclocked with Accelero S1. Internal case temps are pretty cool.
