- 17 Aug 2012
I bought the Krypton Z77 660i bundle along with a MSI HD 7850 Twin Frozr III which I put together last night. I installed a fresh copy of windows 7 and ran a few stress test as instructed in a sticky here with Prime 95 and CPU-Z then ran a 3dmark11 test which came out as normal. I turned on the system this morning and nothing would display on the monitor I tried taking out cables and plugging back in but no change. I plugged the DVI into the onboard video and it worked so I reset the bios then reinstalled the gfx card and it still won't work. Is the gfx card dead should I return it for a replacement ?
Only other things I have in my case is a 500gb Sata drive and a 550w Fatality PSU which all worked fine last night
