I have been deciding on my final system specs which is i7 based with an after market cooler and 5850/70 etc. I have usually bought Asus boards and the P6T Deluxe was my first choice. I am not an ASUS fanboy but you do tend to stick with what you know.
Browsing about the site I then noted this overclocked bundle has the same cooler, memory and CPU I was settled on but it has the Gigabyte UD5 board/
http://www.overclockers.co.uk/showproduct.php?prodid=BU-003-OB
When I add the items in the bundle up they come to only £3 less than the overclocked bundle even adding the thermal paste.
I am not an expert overclocker but I know enough to get a safe overclock. However would this guaranteed 4Gz overclock be a better option? Adding the same components with my original choice of the P6T Deluxe is so close that price it is not worth bothering about.
So my choices are buy the bits separately and overclock myself or get a bundle with the UD5. Personally I am swayed towards the bundle of but it is just the UD5 board that concerns me a little. I had initially discounted it because I had read a few comments about the PCI-E slots being too close for comfort when using crossfire. It is not my intention to do this at the moment but I may want to in the future.
Also I have never had a Gigabyte board so no personal experience of their reliability but reading the web seem that all boards have some issues and the UD5 is no better or worse than others (UD5 Cold Boot issue and the P6T has disappearing memory). It is my thought that getting a bundle means the bits have had at least a power on test, this is another reason for thinking of the bundle.
Is anyone happily running sli/crossfire on this board? if so are temps an issue? It is going into a full tower case so that should help with heat or adding additional cooling if needed.
