Hi,
I'm not usually worried about making my own decisions with regards to my pc setup but in this instance I thought it might be worth checking with the pros.
Bought a overclocked bundle (cpu, ram, motherboard) just over a year ago.
Krypton Intel Core i7-950 3.06GHz @ 4.00GHz
6GB (3x2GB) Corsair 9-9-9-24 PC3-12800 1600MHz
Gigabyte GA-X58-USB3 MB
Now need more Ram for Virtual work and don't know whether the RAM is specifically tuned in to the bios and whether there are any potential pitfalls I should expect or look at first.
The manual for the MB makes the suggestion that when using all six Ram slots, you should use same size, speed, make, model etc. I was hoping to utilise the entire 24GB maximum.
Do I need to find two groups of tri chan 12GB sticks? Do they need to have the same settings i.e 9-9-9-24 or can they be different?
Anyone responding with info, suggestions or experience on this matter would be greatly appreciated thanks!
