- 10 May 2012
- North London
as above n y does u temp say 9 n 29 max??
normally a cpu at idle is about 24-35 and on load about 50 - 70
How can it idle at 8 or 9c? And 1c? Not possible unless you keep your PC in a fridge
The lowest your CPU is going to idle at is just above room temperature.
still not possible.
must be problem with temp sensors then or software
