Overclocked e6300 compared to stock x6800
think i've seen people do a similar thing and there's like a max of 5% performance increase in the 6800 due to the cache, so hardly noticeable! definately not worth the extra £500 lol
The difference between the two would be negligible.
That's what overclocking is all about - making a dirt-cheap processor perform as good as or better than the most expensive one. :D
True - however at the same time the X6800 could then in turn be clocked even higher....
My goal with my E6600 was always to make it perform like a stock X6800.
I've got it 100% stable at 3.2Ghz which is cool for me.
Of course if I had an X6800 I'd be wanting to take it to silly heights.
3.2ghz is just a starting block at the minute, and just because you start with a higher clocked chip doesn't mean that it will then go higher! this was proven with the opteron series with the 144's and 146's out clocking the 148's!
I've read a few topics on people with the X6800 achieving 3.5ghz on air, you dont have to pay £700 for one either Ive seen them for just over £400, thats £170 extra than a E6600 - not sure what it will do on water though, probally similar clocks.
3.5Ghz on air is nothing, most E6600 or E6700s will do that without much hassle.
The big advantage with XE is the multipliers - if you have a sucky board that can't do very high FSB then you could just crank up the multiplier instead. Having said that, why would you be buying a budget motherboard if you could afford a £700 CPU?
If I was paying £700 for a CPU I'd want it to do well over 4Ghz on air, because otherwise I'd just buy one for £350 and spend the rest on a phase changer.
(which is actually what I did)
most of the other core2's are doing 3.5ghz on air though nelly :confused: ? my 6400 is at stock volts and is at 3.2ghz on air! i personally think the limits of the 6800 are very similar to those of the 6300-6700, IMHO the 6800 is not worth any penny of hits high tag price if you are going to overclock anyway!
Durzel what is your e6700 overclocking to under phase change cooling?
el_brato said:
has anyone got a comparison or review/link of a clocked e6300 @ e.g 3.0ghz or greater compared with a stock 2.93ghz x6800 - cheers
If you an email I can send you some benchs which I made for a greek article I just wrote...E6300 OC to 3150 seems to be equal or better to the X6800.
