Overclocked e6600 but not showing in CPU-Z
27 Sep 2005
CPU e6600
Mother Asus P5k Deluxe
Memory 2 GB OCZ Reaper 1066 mhz
ok i have been in the bios and set my FSB to 333mhz and set my multiplier to 9
333 * 9 = 3.0 ghz
in the bios, POST, and my computer it is saying 3.0ghz but i have just installed CPU-Z and it says core speed is 2000mhz with the multiplier at 6 ??
i have disabled the speedstep option in the bios
[img=http://aycu10.webshots.com/image/41289/2002981036899212315_th.jpg]
is both e1st and c1e off? if not then speedstep is not disabled.
sorry if it is and the reply doesnt help but occationally there are some who thinks that only 1 of the above needs to be disabled to turn speedstep off
the only thing i turned off was the intel speedstep option i will have a look in bios now to see if i can see other options
turned off c1e and it is now showing as 3.0 ghz in cpu-z thanks a lot
what temperature's is classed as high? im gonna stress test it now
I think 70c is around your max temp.
What cooler etc you using?
I have nearly the same setup (E6600, P5K) & hoping for around 450x8 to get to 3.6ghz.
What are you using to get temps and stress test?
ok i just been playing cod4 for a good 40 mins and my temps are as follows core 0 - 45c core 1 44c
my cpu voltage is at 1.325
i am just using the stock heatsink and fan but i got lian li case
i am using coretemp to monitor the temps and i am going to use orthos for stress tests
