Overclocked...Please feedback
Hi guys, as you are aware from seeing my signature, im running a PNY 6600, standard, well today I got coolbits 2...
Installed, and I clicked the button which finds the best settings..... My stock core speed is 300mhz, it has been bumped to 348mhz, is this much of an increase? It runs 3d6mark 06 fine, get 2200 points... (roughly)
Should I go a bit higher? It was done by coolbits 2 itself...also, the memory is at 598mhz = "Memory clock frequency"
I have ticked the box in which it leaves the fan on all the time....shall i do apply settings at startup?
Thanks guys, help is appreciated.
Hi guys, as you are aware from seeing my signature, im running a PNY 6600, standard, well today I got coolbits 2...Installed, and I clicked the button which finds the best settings..... My stock core speed is 300mhz, it has been bumped to 348mhz, is this much of an increase? It runs 3d6mark 06 fine, get 2200 points... (roughly)
