- 11 Dec 2005
- Cheshire
For this week's Overclocked friday deal we introduce the all new "OcUK Extreme Intel Core i7 4770K @ 4.60Ghz Extreme bundle".
Clocked up to an amazingly quick 4.60GHz and available with a range of high performance air cooler and water blocks!
Yours for only £659.99 inc VAT!
OcUK Extreme Intel Core i7 4770K @ 4.6GHz+ Extreme Overclocked Bundle @ £659.99 inc VAT
Overclockers UK are now offering the fastest overclocked bundle in the country. Using our expertise we have selected a small number of our best CPU's which we can guarantee to 4.6GHz*, or with improved cooling, much more.
We recommend a good custom watercooling set-up for these bundles, such as our Tech Labs kits (see below) but due to the nature of the chips we are able to reach this speed, stable, on air**. We do not recommend all-in-one watercoolers. If you are at all unsure about the best watercooling set up for you, call us, we are happy to help!
You can choose from one of our specially selected motherboards and choose whether you'd like us to supply a suitable air cooler, watercooler*** or not****
Bundle Specification
- CPU: Intel Core i7 4770K Haswell Quad Core CPU Overclocked to 4.6GHz
- Motherboard: Intel Z87 (Socket 1150) DDR3 Motherboard
- RAM: Kingston Genesis 8GB 1866MHz C11 Dual Channel
- Cooler: Alpenfohn K2 Mount Doom Premium CPU Cooler
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Please allow 7 working days for your system to be built and configured. This may take longer during busier periods. There is no fast track option for these bundles.
Conditions
* We guarantee that these bundles are stable on air, even for heavy real-world use in a case with good airflow and using a good quality power supply. We can offer support but cannot guarantee the OC stability under difficult conditions.
** We do not recommend that you run stress tests such as Prime95 on air as this produces temperature spikes that are never seen during real-world usage which can damage the chip.
*** If we fit one of our recommended waterblocks, you are responsible for ensuring that a sufficiently high quality, leak free, water loop is fitted and that the board is not powered up until the loop is operational. Any faults found to be due to excess heat will not be covered under warranty.
**** If you choose not to buy our recommended air cooler or have a waterblock fitted you are responsible for ensuring sufficient cooling. Any faults found to be due to excess heat will not be covered under warranty.
Only £659.99 inc VAT.
ORDER NOW
Service Package
Conditions
ORDER NOW
