- 15 May 2006
Im only overclocking to 3.8ghz at the moment,from what ive read the power and heat spikes to not a great ratio to performance increase.
Im trying to get as close to my memory mhz with the multiplier at 20 and blck set at 190, im only able to choose 1524mzh (next multiplier is too high for my mem (currently 1800)
Im getting an idle system of around 42 degrees, on a max intel burn test temps do rise to around 74, but a couple of cores stay around 69,to me seems as though i have bodged the thermal paste and probably needs reapplying! Maybe then all cores would stick around 69?
Using Antec 902
Noctua CPU cooler
6gb of Reaper 1800mhz mem
Intel i7 920 D0
Asus P6T v2 Board
Running on CPU voltage, 1.225
DRAM 1.62
QPI/DRAM 1.225
Does this ok to peeps or any thing im doing wrong?
Using Antec 902
Noctua CPU cooler
Intel i7 920 D0
Asus P6T v2 Board
DRAM 1.62
QPI/DRAM 1.225
