Overclocked Stress Tests
27 Jun 2008
Hi, Will be recieving my Q6600 tomorrow so will be ready to do some overclocking, and was just reading the sticky in this forum about the stress tests
Is it necessary to run all of these apps to stress test the CPU? Just wondering as it will obviously cut down time messing about with the CPU if not
Thanks for any help/info!
I'd just run Orthos. Theres little point in the memory tests if the ram will be at stock speeds
would run prime with a quad core, how long and how much you run is really up to you!
Would suggest you give each clock 15 mins on prime just to give it a quick test and then once you reach the o/c you want let it run for a good couple of hours
