I have the annoying problem that my PC will not shutdown or sleep properly.
When I shutdown the via Windows everything happens like you would expect other than the power to the PC is still on. This also happens when you try at put the machine into sleep mode.
This is definitely a problem with the PC being overclocked because if I back the FSB down the PC will shutdown and or sleep properly.
Any ideas?
Any ideas?
