Hi
I have the -
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz / Gigabyte EX58-UD5
Well had to take it into overclockers the day after i received it as would not run ...they found the graphics card was faulty ...but as i had to reset the bios the setting were removed for the 4ghz overclock .
Well they put the settings back in but as there was no operating system on it they did not do a stress test .
Well i have just done a stress test and had a few errors .
[Sat May 30 14:50:04 2009]
FATAL ERROR: Rounding was 0.4921875, expected less than 0.4
Hardware failure detected
[Sat May 30 14:55:24 2009]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
FATAL ERROR: Rounding was 0.48828125, expected less than 0.4
First error was for cpu #0 , second for cpu #1 and the third was for cpu #6
I rang overclockers but they said best to bring it in to them(dont really want to go back there again..long drive ) but is there anything i can try first ? changing settings in bios etc ?
im have never done any overclocking before so very new to this .
Also i keep getting errors in windows vista 64bit which overclockers say prob to do with the overclock settings .
If best to take back than mess about then looks like i will have too
Any help most appreciated
karl
I have the -
karl
