- 30 Sep 2021
- Ex25bh
Hi
Looking at the overclockers build
Intel 10th Generation Comet Lake, Intel Core i3 10105F Quad Core, Intel H510 Motherboard, Up to 32GB 3200MHz Memory, SSD/HDD, 7.1 HD Audio, 500W 80 Plus Bronze Rated PSU, Windows 10, Micro-ATX for £599
Is this a decent spec with good upgrade possibilities in a few yes, or should I build my own? I've changed power boxes, graphics cards and ram before but never built one from scratch...
If you would recommend a self build, what would you recommend for £599?
I already have a corsair rm850 power supply which is unused (needed it to try and bring my old one to life but the PC ist kaput
Thanks in advance
Thanks in advance
