Overclockers Pre-Built Systems
8 Dec 2009
Glasgow
I'm thinking of buying this system http://www.overclockers.co.uk/showproduct.php?prodid=FS-064-OE&tool=5. I trust it is perfectly built and very stable even at the massive overclock, but im not as tech-savvy as most of u so im here asking for clarification as to whether its as good at it sounds.
Im thinking of upgrading it with the Antec 1200 case instead, and taking the ATI radeon 5870. Does this seem fine? or am i making a noob mistake?
You are asking on the OcUK forums, so it could be a tad biased. However, I'd buy that with confidence, OcUK are great system builders and you won't be disappointed. That system is a great spec, and the upgrades you suggest would be just fine as long as your wallet allows it!
Don't just take my word for it though, here's a recent review of a very similar machine built by OcUK.
As usual I'd suggest building yourself if you have the time and confidence. It's not as hard as you may think, and will save you some money. I realise that isn't for everyone though.
If you go ahead, be sure to let us know your impressions.
