** Overclockers UK Official Mug **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Coming soon to OcUK...
Overclockers UK Official Elite Gaming Mug @ £4.99 inc VAT
Introducing the Overclockers UK Official Mug:
'The Ultimate Desktop Peripheral'
Designed and engineered for maximum 'Hot Drink Holding' performance. The Overclockers UK Official Mug leads the way in the fight against thirst.
Desk Mountable for increased stability, the Overclockers UK Official Mug allows you to safely hold hot beverages with its large, ergonomic, easy to hold handle.
Featuring striking graphics on both sides of the Mug, friends and co-workers will know you mean business. It doesn't matter if you are a serious gamer or an overclocking guru, the Overclockers UK Official Mug takes the capabilities of the mug to a whole new level.
A triumph in design, you will never grace your desk with a more capable item.
Developed in conjunction with expert technical staff and overclocking experts, the OcUK mug gives the end user the edge no matter what the scenario
Technical Specification:
• Sleek Black design
• Wide tapered rim for dribble free operation
• Heavy Duty build quality to withstand the hottest beverage
• Unparalleled 'Hot Drink Holding' ability
• Ergonomic Handle Design
• Overclockers UK Logo on both sides
• Compatible with a wide range of hardware configurations
Only £4.99 inc VAT.
ORDER NOW
Any chance of a picture of the other side...? I need to check it will fit on my coaster set up. ;p
Looks good and cant wait to OC it and see how hot my tea can get.
Pre-order incoming...
1. Does it come with a USB to Mini-USB fluid temperature recharging cable?
2. Does it take sides in Ati vs Nvidia arguments?
3. Does it come in hot pink?
