overclocking 10th gen rig
28 Jun 2020
Here is my OC rig .
Got the board and CPU from here .
The Apex works quite well and was able to run CPU just over 57 and my 4000 Cl15-16-16 2T Ram @ 4800 Cl 14-14-14 1T.
Got quite a good score on Cinebench R15 (3166)
Few details missing here. Which 10th gen CPU? 57 multiplier with 100mhz base? if so, 5.7Ghz is good going.
Are you using phase change cooling? What volts was this at?
I can't find the 3166 so this will have to do.
Using an EXC 800 chiller BTW.
Volts a bit high but had the temps to deal with it.
All the info you need is below ;)
a>
pWZQWgG
I can't upload the image
You should be able to click on it and load full resolution ?
https://ibb.co/pWZQWgG
I've just changed the coolant to anti freeze because this chiller can go to 20 below ambient .
So far I have got it to -5 liquid temp .
The earlier run was just water so a bit hotter.
When i get home , whack the air con on and give it another go .
Hoping to get close to 3200.
See if it will get closer to 58 as well .
This is direct die so it all helps
