overclocking 2x2gb pc26400
26 May 2007
What would be the best 2x2gb pc2-6400 memory kit to get if I wanted only a slight overclock (around 860mhz). Will the 2x2gb kits even overclock that far? If so what kind of volts/latency would I be looking at?
Thanks
Thanks
2x2gb kits tend bnot to clock well. At the moment i believe only mushkin do fast 4gb kits in a PC2-8500 package.
Fastest there are but mighty pricy at over £300.
As stinka states... probably best to get 4x1gb of ram.
The Geil Black Dragons are fast and good value:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-067-GL&groupid=701&catid=8&subcat=817
I would imagine you could tighten the timings slightly too running them at 860mhz... they should perform very well.
gt
