overclocking 3570k
Ive just set my multiplier to 45, kept VCore on auto and dropped the PLL down to 1.65.
Running Prime for 1 hour my Core Voltage is reading 1.240 in CPU-Z and may max temps are 75deg C in CPU hardware monitor.
Quite happy with the results to be honest, an easy overclock to 4.5ghz :). ill keep prime running to test for stability but so far its looking good.
BTW im using a Phanteks PH-TC14PE inside a Antec P280 with just the stock case fans switched to low on the cases fan controller.
nice overclock you got there, I'm pretty impressed with these chips so far :)
Dropping the PLL to 1.7 has helped my temps. Now idles at about 30c. Prime95 hits 65c after an hour so happy with that.
Now just waiting for the dual pack of Corsair AF120 quiet fans to come back into stock.
