overclocking 3770k first time
9 Dec 2006
@ManCave
so i just did it.
upped multiper for 42 (only want 4.2ghz)
turned off turbo mode and eist
left voltage on auto, to see what it gives and it goes between 1.192 and 1.2
is this ok or should i try a lower core? if so what is safe to try as lower vcore?
i watched the vcore under load it stayed at 1.128 so i set 1.130 for safety currently running 1.120 nicely on prime 95:D
so 4.2ghz was stable at 1..128
i would like to hit 4.5 for my final oc
tried 4.4 @ 1.140 which got into windows but priome95 failed :(
tried 4.5 @ 1.170 and it didn't get into windows
do you think i should try higher??:confused: or stay at 4.2
yh aslong as temps are ok,you can try lower but I doubt it will be stable,might need even more depends on each cpu
cheers guess it depends if the performance is worth it. highest temperture at 4.2ghz is 40c at the moment
so my stable results so far:
4.2 @ 1.128 [stock max temp 65c]
4.5 @ 1.184 [max temp 71c]
didn't like upping the vcore, little scared of killing it. so got this
4.3ghz @ 1.04 stable so far [max temp 55c] :)
