overclocking 3900X
25 Dec 2021
Serbia
Hi guys.
First time here.
I own Asus Crosshair Hero VIII MoBo and with PBO enabled board gives around 1.46 V (if I remember correctly) to the CPU.
Could check up later in the evening highest voltage when all set to AUTO.
Now don't tell me to update BIOS to latest because I don't want to.
I want to know if that is too high voltage for this CPU (I think so) and would it make my CPU degrade over time?
Because I think it is.
I underclock the CPU to 1.25V manually with x42 multiplier.
Is that okay?
Can I maybe go for 43GHz on all cores and what voltage?
Cooler is H100i platinum from Corsair.
my 3900x is set up with PBO, manual PPT, TDC & EDC limits, offset negative voltage. Your 1.46V is at idle I'm guessing which is normal.
you can also try ryzen clock tuner by 1usmus.
