hi, im new to overclocking and haven't got the slightest idea where to start so if you could put me in the right direction that would be great. my current processor is a amd 5600 x2 + running at 2.8ghz stock and im looking at overclocking to 3.00ghz. thanks
2.8ghz was stock multiplier was set on auto and frequency was set at 200mhz. all i have done is set mutliplier at 14x and frequency at 215 mhz. the cpu voltage is currently set on auto, should i change this ? also should i touch the ram voltage. ive ran prime 95 for an hour max temp was 68 using stock cooler.
