Hello there
My 5850 can do 1ghz core clock at 1.312 stable and fan doesn't go above 35%
When I crank it up to 100% fan speed my card can somehow be stable at 1ghz at only 1.25v
So I take it the cooler these cards run the more stable they are? I know its sounds like basic logic but I thought unless temps go to 85C and higher the temerature shouldn't affect stability or how much voltage the card needs to do 1ghz.
Also what damages the cards, is it the voltage or heat that voltage increase brings?
A lot of people say 1.35v is too much for 24/7 overclock but if the temps don't go above 70C do you think 1.35v is ok for 24/7 overclock?
Thanks for helping me out
