I'm surprised at how well the H110 is coping with a stock 5960X. I guess the real test will be once i start overclocking though.
The H110 gets a lot of flack, but it's genuinely very good, one of the best coolers without going to a full-blown WC setup.
Get some decent fans on there in push-pull.
Use another 2![]()
I used Gregster to sort my 4930k out
I have my 5930k at 4.4Ghz and 1.3V currently. I could try and reduce the V for that speed. My RAM is at 3000MHz but loose timings
My H100i seems to be up for the job tbh. I have 1900rpm Scythe fans on it
Any help would be appreciated
I'm running 4.4 at 1.3v too and with XMP at 3200. Testing stability now and seems stable. Running Rog Real bench max temp so far after 5 minutes 73c with next highest at 70c. Not too bad i guess. Having quite a few problems though with a bd or bf q code on boot. Seems to be vcssa related, but just as i find the perfect setting for it change core voltage or frequency seems to require a new vcssa setting to avoid those q codes. This could take me a while to master.
Sorry ask Matt but could you share your main BIOS settings here?
