- 29 Feb 2012
- London
Whats a good figure to increase by when Overclocking these cards???
Start with the power target set to full. Then try a straight 100 on the GPU clock offset and 250 on the mem.
Run the Heaven 3.0 bench, if all stable go up in 10's on the GPU offset. When that gets to a CTD, back off slightly and then push the mem up (go for increments of 20 on this untill you see artifacts on the screen and then back off that). You can prolly push the mem to something like 450 once you have found your GPU offset max and go from there.
What's artifacts? Heaven settings
Tessellation: Normal
Anisotropy: 16x
AA 2x
And full screen ticked
Are these ok?
Running heaven with the
132
+100
+250
The top card reads
1237
1175
The bottom card reads
1005
1000
Why is that? Is that meant to be doing that?
I'm now running
Evga oc scanner x benchmark
Top card reads
1237
1175
Bottom card reads
1227
1162
What's going on????
Sync is on in evga
Going to try heaven with the extreme options!
Wish me luck
