overclocking 7800gt + vmod questions
Permabanned
14 Jun 2004
autodetect says 460-470 core and 1.14mem, but ive been able to go to 1.25mem (1.3 fails the test).
460 or higher on the core gives bars/beams of texture in bf2, but 450 seems ok.
i tried the vmod, and found autodetect went to 480, but still found beams of texture in bf2. i used the newer nbitor 2.8? and just extended the voltage table and selected 1.5v and flashed it e.t.c e.t.c did i do it right? it didnt seem to go any higher :( i did later realise that i only had one molex lead plugged into the adapter, so i plugged another one in it, so should i try the vmod again??
Xez said:
Did you read the guide on how to do it? Ive done it to my 7800GT but it didnt really help get a much better overclock but i could go slightly higher and getting a my v900 allowed me to overclock even more :p
http://www.planetamd64.com/lofiversion/index.php/t15247.html
thats the one i followed and it worked
yea thats the one i used, but i skipped the old vmod bit and used the new nbitor as you didnt need to change the cards name n stuff. the card doesnt even hit 70c, more like 65c load.
Yes thats +50 on to whatever you overclock it to.. i think its called delta?
well mines sometimes 40 sometimes 50...
I dont know? if i put my clock settings to 480/1250 on futuremark ORb it will register as 520. If im at 490/1250 it says im at 540 on the core
