Currently running an MSI Frozr6 980ti on stock settings... (I think the card is overclocked as standard)
My monitor runs at 3440 x 1440 rez
Is it worth overclocking it - would I get any real gains in FPS in The Division?
Cheers
spluff
Try it and see.
What clocks does it boost to now?Currently running an MSI Frozr6 980ti on stock settings... (I think the card is overclocked as standard)
Cheers
spluff
cool gamble how do you do that
I think mine is 1140 normal 1290 boost and memory 1753
Ive got MSI card so makes sense to use that
Do you have to load afterburner each time you want to overclock? Or does it write to the card?[/Q]
it doesn't write to the card and need MSI to run when you want to use that overclock
I have a default fan profile setup within MSI afterburner so I set it up to run the application on startup which meansI can set my day to day overclock on boot, as well as my custom fan setup.
What you will find however is that some overclocks will run better than others. GTA for me runs 300 clock, 400 mem, whereas what I posted earlier is for division and nfs.
