Overclocking a 6600k
17 Mar 2009
Atm I have a overclock of 4.6 Ghz @ 1.36 core, I'm trying to decrease the volts but the supplied Asus AI Suite keeps pumping it up to 1.4, anyone either have a profile or can point me in the right direction, regards
Overclock from within the BIOS, uninstall AI Suite if necessary if it still does that after the BIOS OC.
That's if you are sure the problem is with AI Suite and not perhaps an Adaptive overclock adding on a bit more voltage when CPU is stressed by some programs.
In any case, BIOS overclocking is always recommended over software in Windows. You can also tweak the fan profiles from within the BIOS as well.
Yeah I did some researching and did a 4.6 Ghz overclock @ 1.35 but then I tightened up the voltages and settled for 4.5 Ghz @ 1.26, time to uninstall AI Suite.
