overclocking a 670 (gigabyte windforce)
5 Jun 2005
Southampton
dunno if its worth it or not, as never really had high end gcards and certainly not overlocked before, just after some tips for my card, what software and so on?
Use EVGA Precision or MSI Afterburner.
I use EVGA precision, but have used Afterburner as well.
Good luck with the o/c! :)
I also use EVGA precision X. Start with something small like +50 on the GPU and plus 100 on the men. Stick the top slider to full (132%) on my card and stick the fan on full whilst testing with something like Heaven.
Have fun and go up slowly with increments of 10 on both
This is what i got upto. BUT this is MAX o/c take it SLOW as gregster says if you try to get upto this level. These are not 24/7 clocks!
Good luck with the silicone lottery. You have a good card type there. I hope its a good clocker!:)
http://www.techpowerup.com/gpuz/wq724
Full size grab > http://i102.photobucket.com/albums/m81/Speedy_Pete/OcUK/00020-1.jpg
GPU details in sig
Core 1300MHz
Mem 7574MHz
