Permabanned
- 16 Sep 2003
- Plugged into the Matrix
Ok, I seem to be having a little trouble overclocking my card. I have installed the 96.98 drivers which support my card and all is working fine except for when I try to overclock the card. I have the lastest version of Ntune installed too 5.05, but when I press 'find optimal' it locks up my pc. Im sure you could just manually adjust the slider bars before and then after testing accept the overclock, but it does not let me select 'custom clock frequencies'
Strange thing is I was having a similar trouble with my GX2 so I used the latest RivaTuner and that worked ok, but I dont think the current version supports the 8800GTX.
Any ideas anyone?
Any ideas anyone?
it should work fine with that driver.. You can download from the link below or you can probably just get it from your driver CD that came with your card.. Much better then crappytool..
