Having armed myself with a gtx 670, & seeing how demanding farcry 3 seems to be, I wondered if my phenom II 965 BE was holding me back somewhat. Thought about upgrading then thought about overclocking..never done before...
Here's what's confusing me atm...everywhere I read about oc'ing, I read about upping northbridge/memory timings (along with cpu multiplier/voltage)..then I come across this post elsewhere...
"You have a Black Edition CPU so all you need to do is increase the multiplier & possibly the CPU voltage to stabilize the overclock. That's the whole idea behind the BE CPUs. There's really no need to mess with any of the other settings.
AMD systems have no FSB. The CPU & memory controller communicate at full processor speed, so the higher you clock the CPU, the faster the CPU-memory communication. Increasing the RAM speed will have very little effect on performance. In the Tom's article I linked to in your other thread, it mentions that an overclocked CPU with DDR3-800 will perform better than a non-overclocked CPU with DDR3-1333. The key is to run the CPU as fast as possible, while keeping the HT & memory buses at their defaults speeds. Even so, the X4 965 BE is already near the upper limit of what the X4 is capable of. You'll be lucky if you can hit 3.8GHz & remain stable. Hopefully you have a decent PSU because your CPU is rated at 140W. Overclocking will increase the wattage."
(link http://www.computing.net/answers/cpus/overclocking-on-asus-m4a79xtd-evo/16738.html )
So now I'm confused as to whether I have to mess with northbridge/memory or is it as easy as cpu multiplier/voltage as the above para suggests with the BE editions?
Mobo is m4a79xtd evo if it makes a difference.
TIA..Andy.
TIA..Andy.
