I'm quite new to overclocking graphics cards but I've read a few guides on it. I have MSI Afterburner to change my voltage, core and memory clock settings. I also have GPU-Z to check the temps while testing and I am using Unigine Heaven as the benchmark.
The default settings on the MSI Twin Frozr II were a core voltage of 0.975v which I have increased to 1.05v. I increased the core clock from 880MHz to 950MHz and increased the memory clock from 2000 to 2200MHz. I tested this in Haaven and it seemed fine with no artefacts or crashing with temps maxing at 70 degrees with a fan speed of 60%.
Is this benchmark sufficient or do I need to do other things like Furmark? I tried Furmark earlier and the temps reached 90 degrees which was a bit worrying but it isn't a realistic benchmark for gaming is it?
Finally can I increase my overclock some more or just keep it as it is? What is the max voltage and temps I should be reaching?
