Overclocking a i7 920
8 Jun 2005
London
Hey there..
My i7 turned up yesterday, got it all up and working no problem with 2x 260GTX's in SLI and 6GB G.Skill, on a Asus P6T Deluxe x58..
I'm currently on stock cooling but was wondering how far I should be able to push my chip, and what are the best settings to change?
Cheers
4Ghz is not going to happen on stock cooling. I'm running 3.8Ghz @1.28v and my load temps get to 80c with the Noctua NH-U12P. To go from 3.8Ghz to 4Ghz I have to add an extra 0.12 which increases temps considerably. This is with a 27C MB temp so its not extactly hot in the case. These chips run really hot so you may get 3.6 with the stock cooler but its still going to get pretty toasty.
they don't run that hot, for the bottom of the range i7 to reach nearly 4 ghz on air ( some people have done it with the stock cooler!). to reach that speed at all without going to 100'c is quite good.
Lmao, don't run that hot? Try it at 4Ghz (1.35v+) with 8 thread HT enabled on Prime blend and see what happens. Even with good air, its going to get toasty.
I'm not saying they don't clock well but even when running stock they create a lot of heat. My Q6600 at 3.0Ghz with a tuniq never got above about 50c at full load. The i7 at the same clock is more like 65-70c.
i'm at 3.5ghz on stock cooling, and i'm hitting 80 under prime95. but bare in mind i have very bad case cooling.
i have seen some cases of people getting 4ghz on stock cooling, but i feel thats pushing it a little.
I7 are super toasty when overclocked.
Mine is idling right now around 34-35C but so it should as I have a Noctua HP12 with 2 fans in a push pull config and very good case ventilation and all the Intel tech to lower volts/temps enabled. Under heavy load on all 8 cores it gets to 75C very quickly.
The stock HSF which comes with the I7-965 is the best one Intel ship and a different design to the 920+940 HSFs. Even then it idles around 47-48C with AS5 and under heavy load hits 80-85C even on a very cold day like today.
Doing a massive overclock on the stock HSF is asking for trouble. Also be aware that you need to keep your DDR3 volts below 1.65V according to Intel. Any higher and you may damage the CPU permanently!!
