Hi,
Ive got an P4 @3.2ghz (Socket 478
) on a Asus P4C 800-E Deluxe with a oversized Zalman cooler of some form (will check if need be)
Tried to overclock it using the inbuilt Asus settings, but the "overclocking failed" constantly.
Just wondering how I would go about overclocking it manually (never done anything to do with oc before) and if the "overclocking failed" message has anything to do with BIOS xD
Thanks in advance
) on a Asus P4C 800-E Deluxe with a oversized Zalman cooler of some form (will check if need be)Tried to overclock it using the inbuilt Asus settings, but the "overclocking failed" constantly.
Thanks in advance
