Overclocking a Phenom x4 9650
13 Sep 2009
Maidstone, Kent
So I have a pretty average Phenom 9650 at stock (2.3) with a stock cooler. Basically I want to overclock a bit, preferably without using the BIOS or over-volting (cant really afford a mistake!). So which cooler should I be looking at, how much should I overclock and how?
I have some overclocking software that came with the mobo T-series oc utility, with allows you to test, so if it is unstable, it will restart at stock settings.
