anyone?
so which of those overclocks are the best ?that was type error i meant 1333at 3.2 your fsb is 400 not 1600
try priming on either, i prefer using the 8x for this memory
FSB rated at 1333 not 133
sounds good, id keep an eye on the pwm temp as it can be a little flakey on this board especially if the tuniq is very close.
dunno if he was joking but he didn't sound like it.O core temp also sees my cpu at 3.6ghz thou cpu-z says 3.2 and so does the bios. Is this normal?
According to Abit tech support the mosfets on the ip35 pro can take anything upto 125cdunno if he was joking but he didn't sound like it.
^ Did you RMA to the etailer or Abit? If Abit what was the turn around time?
