Asus p5q pro but had the same abit ip35 pro before and it made no difference on that either I only think it might if you use 4x sticks of ram.
i also found this on my DFI DK P45 t2rs+, i just left the NB at stock voltage.
i also just have 2 sticks of ram
@gazzaa, as i said, bump the volyage upto around 1.4-1.44v.
then raise the fsb in 20mhz steps, and run the stress test between steps.
at that vcore, with a good cooler you should get to around 3.4-3.6
what cooler have you?
