Hey fellas,
Had a Q9300 for about 18 months. Finally decidided to do a bit of an overclock on it to try and get it up to 3.0GHz. My first time overclocking so things are a bit up in the air and I'm not entirely sure what I'm doing.
Hardware-wise I have the following set up:
Q9300 @ stock ~ DFI LAN Party P45 T2RS ~ Noctua NH-U12P ~ 4GB Corsair Dominator RAM ~ Saphire Radeon HD5830 ~ OCZ 'Mod-X-Stream' 900W PSU ~ 2x200GB Seagate Barracuda HDD's ~ Antec 900 Case
Everything is set at default values except the DRAM Voltage which I've upped to 2.0v (RAM is rated at 2.1v).
As I said, I'd like to up the speed to 3.0Ghz, with an FSB of 400Mhz (on a 7.5 multiplier). I've read the introduction to overclocking sticky so I know the basic procedure. My main query is which voltage(s) to up when I get to an FSB that's not stable at the set voltages?
Going into the voltage settings, I have the following options:
CPU VID Special Add
DRAM Voltage Control
SB Core/CPU PLL Voltage 1.55, 1.75, 1.95 or 2.15V
NB Core Voltage 1.1825 --> 1.9700V
CPU VTT Voltage 1.10 --> 1.60V
Vcore Droop Control --> On/Off (currently on)
Clockgen Voltage Control --> 3.45, 3.60, 3.75 or 3.85V
CPU GTL 0/2 REF Volt --> 0.67x, 0.63x. 0.61x or 0.58x
CPU GTL 1/3 REF Volt
North Bridge GTL Ref Volt
FSB Vref
Temperatures seem to be reasonably low, current temperatures are:
Temp1: 18C
Temp2: 32C
Temp3: 39C
I might be reading the wrong temps though.
I managed to get it up to an FSB of 350Mhz last night (speed = 2.625GHz) but beyond that seemed a bit unstable so I've dropped things back down to stock speeds.
I appreciate any and all advice,
Cheers,
Jim
CPU VID Special Add
FSB Vref
Temp1: 18C
Temp2: 32C
Temp3: 39C
Cheers,
Jim
