- 29 Mar 2010
Hi folks
I was hoping someone could give me some advice or share their wisdom.
I've attached a spreadsheet which I've been recording my overclock settings. As you can see, I seem to have it stable at 5.2GHz @ 1.36v with AVX offset @ 1.
Now, I feel like this is a pretty decent OC, but I was wondering if there was anything I could do or try to squeeze a little bit more from it? Or what would be your opinion on what I should do, keep it as is, or tweak more to maybe get a bit more?
I haven't adjusted Max/Min CPU Caches, they're still set on Auto. Would they be worth looking at?
BTW, temps are decent @ 80ish C under heavy/max load. The 8086K has been delidded and liquid metal applied. I'm running the NZXT Kraken X62 for cooling.
Thanks in advance for any responses/help.
- Motherboard: ASUS Maximus X Hero (non WiFi)
- CPU: Intel Core i7-8086K
- GPU: Zotac GeForce GTX 1070 AMP Edition 8192MB
