Overclocking advice for XFX 4890
11 May 2009
Hi all,
I'm new to Graphics Card overclocking and was looking for a few pointers really as to what I can achieve (If anything) on stock volts and cooling for the card in the title.
The graphics card is the bog standard version, not XXX or anything like that.
Also what program would you recommend for doing the overclock, CCC Overdrive?
Thanks in advance.
Just use CCC, you can only go as high as overdrive will let you anyway, so other software is just not worth bothering with. Suggest you use manual fan speed to keep temps in check if they go high with stock speed.
