- 29 Jan 2008
Hi there,
I’m new to OC and was wondering if any of you knowledgeable people could assist me ?
Specs:
ASUS P5KC (BIOS: 0804)
2.20Ghz Conroe dual (x11)
2x 1Gb DDR2-800 GEIL CL 4-4-4-12
I’ve been reading up on the OC scene and attempted to OC my Conroe.
I run the Prime95 for about 20-30 mins after each change and 250mhz (2.76Ghz) seems fine and I ran 3DMark03 which was also fine.
The Problem
I’ve upped the FSB now to 250mhz, anything above this either doesn’t load into windows (restarting) or when it does, restarts after running stress tests.
As I’m new to this, I’m guessing some settings need to be corrected in order to allow me to OC further.
CPU FSB: 250Mhz (multiplier just left on auto x11)
RAM: 375Mhz
PCIe: 100Mhz
My Settings are below:
AI Overclocking Manual
CPU Ratio Control Auto
FSB Frequency 250
PCIE Frequency 100
DRAM DDR2-625Mhz
DRAM Timing Control manual
CAS# Latency 5
RAS to CAS# Delay 5 DRAM Clocks
RAS Percentage 5 DRAM Clocks
RAS# Activate Percentage15 DRAM Clocks
TWR Auto
TRFC Auto
TWTR Auto
TRRD Auto
TRTP Auto
DRAM Static Read ControlAuto
DRAM Dynamic Write Con Auto
Transaction Booster Auto
Clock Over-Charging ModeAuto
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
CPU Voltage Auto
CPU Voltage Reference Auto
CPU Voltage Damper Auto
CPU PLL Voltage Auto
DRAM Voltage 1.9v
FSB Termination Voltage Auto
Temperatures Haven’t changed as of yet, both my thermal controller Probes give about 29-31C readings, of course these aren’t accurate but it gives me an idea of what to compare it with. (Using an ASUS heatpipe Heatsink with a Thermaltake 80mm fan capable of 80CFM on max)
Also, I haven’t quite grasped the RAM Ratios, also, would it be advisable to run the ram at 4-4-4-12 as to 5-5-5-15 ?
Here's some screenys:
Specs:
The Problem
RAM: 375Mhz
PCIe: 100Mhz
FSB Frequency 250
PCIE Frequency 100
DRAM DDR2-625Mhz
CAS# Latency 5
TWR Auto
TRFC Auto
TWTR Auto
TRRD Auto
TRTP Auto
CPU Voltage Auto
DRAM Voltage 1.9v
Also the temp got to 55 with my AC freezer 7 pro. I've got 0903 bios, theres a new one 1001 which i'll flash b4 installing new ram as it got "Enhance compatibility with certain memory module."
