Ive recently purchased a rig from OC which is a gigabyte
Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor
Gigabyte ATI Radeon HD 7850 OC Windforce 2X 2048MB GDDR5
TeamGroup Elite 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
Thermalright True Spirit 140 CPU Cooler
NZXT Phantom 410 Midi-Tower Case with 2 extra case fans
And have a couple of questions i could do with help with, my pc is running at 27 degrees when idle
1. Im a little confused about the CPU its stated as 3.5ghz yet in windows it says its running at 3.9 ghz and ive not overclocked it, does it overclock itself or change from 3.5 to 3.9ghz? in the bios its set to 35 x 100
2. Ive been running BF3 on it in full settings ultra etc and im only getting around 35 45 fps, what kind of fps should i be getting on a i7 clocked at 3.9ghz ? a friend of mine has a 1st generation i7 and says he can run at full at 60fps ?
3. What speed can i safley overclock upto and how should i do it, do i change to 45x100 or not ?
4. What speeds can i safley upgrade my memory to its 1600hz and is it worth upgrading my memory ?
5. Is it possible to upgrade the graphics card, if so how ? is it best to OC GFX or should i focus on the CPU.
Any help would be appreciated
thanks
thanks
