I found someone wrote this, seems like he has the same specs, but could someone explain what he has done, and I have faster memory so how would I go about it???
quote: Just built a new machine with Athlon II X2 240. Got mine up to 3.2GHz (14 x 228 MHz). Not sure if, or how, my ASUS M4A78LT-M-LE board will let me alter the FSBRAM ratio, but the memory chips are probably at their maximum at 607 Mhz FSB (got DDR3 1066MHz running at 1214MHz). But the system is stable at 39C under full load (30C idle). It looks like a good overclocker, so I may invest in some faster RAM and push it a bit further. Things have come along way since I used to overclock my old Barton CPU (ran very hot).
