I'm running an R0 E5300 on a Gigabyte EP43-UD3L with 4GB of Kingston HyperX PC2-8500 RAM.
So far I've managed to get it 1 hour OCCT stable at 3.6GHz. I've kept the FSB/DRAM ratio at 1:1 as I think I've heard that it's best performance wise to keep this ratio if possible. I've adjusted the core voltage to 1.312 for this overclock and the FSB is running at 1108, quite a bit higher than my RAM's rated frequency of 1066. I'm still using the stock Intel HSF but as my case has fairly decent airflow the temp doesn't go above 60 on load.
My query is if I want to push this to 3.8/4.0Ghz then what's the best way to go about it? Would the extra couple of hundred MHz be worth losing the 1:1 FSB/DRAM ratio?
Thanks
Thanks
