Hi there, assuming you mean the i7 920 in the title.
May ask if you have the C1/C0 or D0 stepping of this chip (as it affects how you go about overclocking it)? You can check using CPU-Z.
Also, do you have an aftermarket cooler or just the stock one? If it's just the stock one then I wouldn't suggest overclocking until you get a new cooler as these s1366 chips are very hot and they get much hotter when overclocked.
Also, may I ask what exact motherboard make and model you are using?
