Overclocking and MCH Strap(?)
21 Sep 2006
Can someone please explain to me about the MCH Strap?
I have a 965P-DS3, E6600 and 2gb Geil ULL Ram.
I'm currently overclocked at 430x8 - 2.4ghz and ram at 1:1 = 860mhz 4-4-4-12.
Am I hitting the different MCH strap due to my 430fsb?
I'm just clueless about this MCH strap.
Thanks in advance.
My understanding of straps is that (where the board has them), is that the chipset timings change at a set point to allow higher FSB beyond that point. Because the timings are looser you loose performance in chipset intensive tasks, so you need to make up a lot of ground on the FSB to compensate.
Jokester
A "strap" refers to the set of internal timings and internal bypass routes of the MCH.
The strap is set on a MCH reset via BSEL pins and latched into an internal read only register. The frequencies the "strap" changes at is manufacturer firmware dependant as virtually no-one follows Intel design guidelines regarding this.
On your system your MCH core clock is 484MHz on a 1333MHz strap. If you're happy with it, it's fine...
