Overclocking and shaders
13 Sep 2009
Maidstone, Kent
I am going to overclock my GTX 550 Ti and am wondering if there is any relation between the core clock and shader clock. Could you please explain the relation and help me calculate it? Cheers!
Assuming it is the same as the GTX4XX then the shader clock is exactly double the core clock. As you increase the core by 10MHz the shaders will automatically be increased by 20MHz.
Spot on! Had a look at a few reviews with overclocks and it seemed to go up by 20MHz for every 10MHz on the core. Thanks for confirming it as I was unsure.
