Overclocking - Applications advice
7 Feb 2004
I have looked through the thead on applications but am still unsure which is the best to use for testing overclocking.
I plan on doing it with my CPU to see how far it will go. I have got it to 3.4ghz before but would like to test to see how it handles a little higher.
Same goes for graphics cards if possible. Any applications that run reports so you can leave and check back later rather than these ones that just monitor the current temp.
Thanks
Orthos is widely regarded as the daddy of CPU/Mem/Mobo stress testing. The 'Post your stable OC's' threads require Orthos screenshots for validity.
For a GPU then any GFX intensive game that has a built in benchmark. Make sure you the rest of your rig is stable though.
