Probably a silly question but i'll ask it anyway! Is there any danger to the CPU if you overclock it without upping the voltage? I've got my E6750 to 3.2 on stock volts (stable in prime). Am i doing it any damage?
I think most people start their overclocks by increasing their FSB or playing with the multiplyer first, then when it's unstable start upping voltage. I've not heard of any dangers in doing so - it seems the norm. In fact I've read that some people prefer not to increase voltage at all for dear of increased temps and frying their CPU. This should help though.
Thanks for the responses. The only things I noticed were a small drop in the voltage at load (is this vdroop?) and slightly increased temps. Temps appear to max at 40C so no harm there.
I read that guide btw - very helpful.
I think it should be okay to leave it at 3.2. I have speedstep enabled so it's at 2.4 most of the time anyway.
What are you using to test load temps? Something like Orthos or Prime95 would be good. Leave it running overnight to see if your overclock is stable and to get a true look at your load temps.
I don't have an Intel, but don't most people disable Speedstep when overclocking?
